omega_rugal Posted May 2, 2020 Share Posted May 2, 2020 oh the hated BA10/5, the weakest tranny behind the 4.0, nobody wants it but a can a pukegoat be of any use? i think it can... well, the bellhousing that is. from the pics i have seen appear that an external slave cylinder can be bolted to it theres a hole where the fork would pivot and from outside there appear to be holes for the slave cylinder bolts isnt it easy to drill an adapter plate to fit this bellhousing to something else, like a ford or GM tranny? plus, theres a slot for the CPS already Link to comment Share on other sites More sharing options...
Pete M Posted May 4, 2020 Share Posted May 4, 2020 I wonder if any car that used the Peugeot have an external slave... Link to comment Share on other sites More sharing options...
omega_rugal Posted May 5, 2020 Author Share Posted May 5, 2020 On 5/4/2020 at 8:31 AM, Pete M said: I wonder if any car that used the Peugeot have an external slave... i didnt find any info on the BA10/5 but its relaitves BA7/4 and BA7/5 apparently did have external cylinders, which could explain the holes to screw the slave and the pivot ball, most of the info is in french so i don't understand anything... Link to comment Share on other sites More sharing options...
