Reverse Light switch
Alright guys 2nd post today, might be more since there is nothing to do because of the corona virus. So I'm working on fixing my reverse light switch, thought it was broken but turns out it might not be, instead when I got down there the wires were cut after like 3 inches. Does anybody have a diagram showing me where the rewire them to
Those wires run to a connector (or at least used to) that winds up coming out up by the heater hoses on the firewall. Comes up through in a 2 wire harness past the starter. Search thatvgeneral area and you should find either a 2 pin weatherpak connector hanging down, or a chopped up harness coming from under the trans tunnel.
