nknapp16 Posted February 18, 2020 Share Posted February 18, 2020 I did my DD, but no luck. Currently only works on high. Need to rewire the resistor, wiring is shot, connector was melted. Blows air lightly through vents or defrost. Seems better when set on cold. Heat seems to have even less flow. New blower, switched polarity, didnt help. Deff had resistor problems before, melted the plastic housing, I made a pretty sweet duct tape replacement housing that's air tight. Checked vacuum lines only found one blue one that isn't connected to anything. Anyone know if this is supposed to connect somewhere? Sent from my SM-N970U1 using Tapatalk Link to comment Share on other sites More sharing options...
Ωhm Posted February 18, 2020 Share Posted February 18, 2020 Should be Air Vent Filter (#3), if equipped. Link to comment Share on other sites More sharing options...
