Inconsistent Idle
My truck seems to randomly pick what speed it wants to idle at. Sometimes as low as 300 rpm, once as high as 2000 rpm. This can change while I am driving it, and usually jumps up to around 1300 rpm when I throw it into park after driving it for a while. Also my part time light stays on most of the time even though I am in 2H, but turns off when I accelerate quickly.
Any ideas on what is going on?
I have the same issue, but its unclear to me what the answers may be listed above? renix system issues?
On 1/24/2020 at 5:59 AM, BizarroStormy said:
Looks like I have some projects for the weekend. Thanks, I will report my results.
  • 1 month later...
So I did most of the tips and it didn't change my idle issue, that C101 connector was disgusting though. I replaced my air control valve, throttle position sensor, MAP sensor, and oxygen sensor (all at once) and it solved the issue.
My truck Idles around 800-900 rpms now and doesn't go crazy while in park.
Hopefully this will help my gas millage, I was getting around 13 mpg before swapping the parts.
Thanks for all the advice :smile:.
