MancheRachel Posted January 13, 2020 Share Posted January 13, 2020 1989 Jeep Comanche Pioneer 4.0l with a 91 4.0l swapped in (in the process) Manual 4x4 8.25 Chrysler swap, both axles have been swapped out. Longbox -Stock Equipment from build sheet- Monotone Paint Command-Trac Part Time 4WD System 230MM Front Axle 3.07 Rear Axle Ratio 175MM Rear Axle Black Powder Coated Front Bumper Black Front Bumper Front License Plate Bracket Body Color Headlamp Bezels Black Windshield Moldings Grille Surround-Painted Silver Control System Catalytic Converter Engine Block Heater Power Rack and Pinion Steering Alcantara Wrap Steering Wheel Standard Duty Shock Absorbers Rear Shock Absorbers Tire Carrier Winch Sold for $10,188.44 in 1989 Canal Flats, British Columbia, Canada Status: Currently swapping in a 91 4.0l. Has a 4" lift on 32s, interior is swapped out with two bucket seats and a centre console, the whole cab has been replaces and line-x sprayed with plugs, and original matching canopy, also has a mack hood ornament. Current owner: myself, before it was owned in Squamish BC, before that it came from Penticton BC- someone has already claimed they owned this truck about ten or more years ago in the Okanagan. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 13, 2020 Share Posted January 13, 2020 *X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 126 Zone 26-Canada-Pacific 1AB Canada Dealer Retail 5AM Largo Tracking ACC Southwest Edition ADL Skid Plate Group APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JDB 180 KPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB MOPAR Hood Lock K2X STRIPE/BADGE/MOLDING/COLOR K3E STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon NHK Engine Block Heater PE8 DARK VIVID RED PRIMARY PAINT - HE8 QE8 DARK VIVID RED SECONDARY PAINT - HE8 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TAD HIGHWAY TREAD TBB Full Size Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAC Build To Canada Mkt. Specifications YBA 30.2 Liters Of Diesel YGA Without Billable Fuel Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 5/30/89 Body code JM62 Link to comment Share on other sites More sharing options...
MancheRachel Posted January 13, 2020 Author Share Posted January 13, 2020 Thanks for the build sheet! Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 13, 2020 Share Posted January 13, 2020 No problem! Link to comment Share on other sites More sharing options...
jdog Posted March 30, 2021 Share Posted March 30, 2021 Selling Dealer: DEER LAKE PLYMOUTH CHRYSLER LTD Vancouver, BC (CAN) Link to comment Share on other sites More sharing options...
