CDALE Posted December 31, 2019 Share Posted December 31, 2019 Hey Peeps, I have acquired an 88 MJ and trying to piece the front end together. Ive sourced some things and have a radiator that came from an automatic and has the trans cooling lines coming from the radiator. I'm looking for a locking nut to mount the trans cooling unit to the radiator. Right now it is loose and radiator isnt holding fluid (def not a good thing lol)...basically looking for a locking nut of sort to seal my radiator. ive cut the trans cooling line Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted December 31, 2019 Share Posted December 31, 2019 So you have a manual truck? If so , Flush it out with brake cleaner and nothing should come out of the trans cooler . Link to comment Share on other sites More sharing options...
CDALE Posted January 2, 2020 Author Share Posted January 2, 2020 I do have a manual, the problem is on the radiator there is a nut that hold the unit inside of the radiator still. I am missing those nuts so the radiator is pouring fluid. Link to comment Share on other sites More sharing options...
Warren Mohler Posted January 2, 2020 Share Posted January 2, 2020 on a lot of aftermarket rads. that nut is a sheet metal type, should be able to find at JY. still may leak if antifreeze if whats leaking do to build up of debris inside tank. give it a try. replacement rads. are fairly cheep and easy to install Link to comment Share on other sites More sharing options...
CDALE Posted January 3, 2020 Author Share Posted January 3, 2020 i thinking a radiator is the way ill end up going. Thanks for the help Link to comment Share on other sites More sharing options...
