hedbutter Posted November 1, 2019 Posted November 1, 2019 I'm looking at getting a MJ and building a mild offroader to play around in. Plan to swap the leafs to mount on top of the axle. Once the mounting points have been moved, does that allow for XJ leaf springs and kits to be used? Sent from my SM-G965U using Tapatalk
89 MJ Posted November 1, 2019 Posted November 1, 2019 No. The springs are different lengths. You could just go spring over axle with the MJ springs and get about 4-6 inches of lift.
hedbutter Posted November 1, 2019 Author Posted November 1, 2019 No. The springs are different lengths. You could just go spring over axle with the MJ springs and get about 4-6 inches of lift. Thank you! I figured that was the case but wanted to confirm (the searches I've been using aren't bring up what I expected). Hopefully getting the 2wd Comanche this weekend and then will be on the lookout for the 97+ donor to get the project underway. Thank you!Sent from my SM-G965U using Tapatalk
