Dal3 Posted September 24, 2019 Share Posted September 24, 2019 The hood release cable on my 89 Comanche broke and I pulled the housing into the cab and out of the latch, so 'll have to go at the latch. I looked up at the latch from below and, in the latch area, I only see a small metallic -finished metal tab inside a circular hole punched in the body metal the latch is mounted to, I think. I fiddled with this tab, including with the grill off and didn't get any actions for my efforts. It might help if had a latch I could examine, but I don't and can't find good pictures. I couldn't find instructional videos online, except one involving a much newer model that appeared to be different. I'd appreciate information about getting the hood open again. Thanks. Dale Link to comment Share on other sites More sharing options...
jason.cook.52206 Posted September 24, 2019 Share Posted September 24, 2019 Here are a few photos. Hope it helps.Sent from my SM-G935V using Tapatalk Link to comment Share on other sites More sharing options...
Dzimm Posted September 24, 2019 Share Posted September 24, 2019 If you can reach the metal bar that runs across between the latches and yank it sideways it will release. This will also be of use. Link to comment Share on other sites More sharing options...
Eagle Posted September 24, 2019 Share Posted September 24, 2019 Don't you guys know about stickie posts/threads? https://comancheclub.com/topic/829-what-to-do-if-your-hood-release-cable-breaks/ Link to comment Share on other sites More sharing options...
Dal3 Posted September 25, 2019 Author Share Posted September 25, 2019 Thanks. I thought the main release was the center latch and was looking there. I'll look again tomorrow and try your suggestions for releasing the side latches. Dale Link to comment Share on other sites More sharing options...
Dal3 Posted September 28, 2019 Author Share Posted September 28, 2019 I got the hood open and replaced the release cable. Thanks Dale Link to comment Share on other sites More sharing options...
Dzimm Posted September 28, 2019 Share Posted September 28, 2019 Sweet! Link to comment Share on other sites More sharing options...
