4.0 HO TB outside diameter/intake elbow inside diameter
Can somebody measure the outside diameter of the 4L HO throttle body?   Or the inside of the intake elbow that goes on it?  I think it's 2.5", but it might be 2.75".
Trying to order an elbow to make a new intake...  Without any parts in front of me.
5 minutes ago, DirtyComanche said:
Thanks!  Oddball size, but I'm sure I can find some silicone elbows.
That's the outside lip - outer diameter including the little nipple that runs along the top edge .  Maybe I should have said that.  The actual diameter, excluding the nipple, is likely extremely close to 2 1/2".  So if your 2 1/2" elbow can expand to 2 5/8" to get past the nipple, that would probably be optimal.
