KeppyMJ Posted July 8, 2019 Share Posted July 8, 2019 Fuel pump wiring was messed up by previous owner so I hot wired from 87 on the fuel pump relay and the pump works great but only starts for about 3 seconds. Did I skip over something and the ECM is freaking out? 1988 4.0 Link to comment Share on other sites More sharing options...
Ωhm Posted July 8, 2019 Share Posted July 8, 2019 Year?? Engine?? Link to comment Share on other sites More sharing options...
KeppyMJ Posted July 8, 2019 Author Share Posted July 8, 2019 1988 4.0 Link to comment Share on other sites More sharing options...
Ωhm Posted July 8, 2019 Share Posted July 8, 2019 You removed the fuel pump relay, hot wired pin 87, started engine, engine dies. Was the fuel pump still running after the engine died? Link to comment Share on other sites More sharing options...
KeppyMJ Posted July 8, 2019 Author Share Posted July 8, 2019 Didn't remove fuel pump relay just tapped into wire 87 for the fuel pump and not sure on if fuel pump is still running after it dies I will see. Thanks for the quick response! Link to comment Share on other sites More sharing options...
KeppyMJ Posted July 9, 2019 Author Share Posted July 9, 2019 Figured it out, I had to connect the factory fuel pump wire with the harness I made and it now runs great Link to comment Share on other sites More sharing options...
