1JTHA6618GT036500
TJ Jones
1986 Comanche Custom. 2.5 L with Throttle Body Injection. Three speed torqueflite (mopar) automatic transmission. White with straight red bench seat without headrests. A/C removed by a previous owner, leaving pump in place. 2WD. Driver side floor pan replaced. Bedliner removed, no rust underneath. Stock 15" tires and aluminum wheels with no lift. Build date worn off of inside door. 159,000 miles. VIN 1JTHA6618GT036500. Northeast Miss ippi. This engine and trans setup - only between 30 and 40 built.
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT
-ZZ
BAC 75 AMP ALTERNATOR
BCQ Battery - 750 Amp Maintenance Free
CGX Head Restraints-Outboard Seating, RR
DGZ Transmission- 4-Spd. Automatic,MT643
EPD ENGINE - 2.5L I4 TBI GAS
GAC ALL WINDOWS - TINTED GLASS
GSC MIRROR - RIGHT BLACK
HAA AIR CONDITIONING - FRONT
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JJA CIGAR LIGHTER - FRT COMP
LMA HALOGEN HEADLAMPS
MBJ Bumper - Front, Black
MD8 Delete Front License Plate Bracket
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
NFA TANK - 20 GAL FUEL
NMB ENGINE COOLING - STANDARD DUTY
Base truck yet has AC? Well someone had their priorities right for this one.
Build date: 9/4/85
Body code:TL62
  • 11 months later...
