Converting the Ba 10/5 to the AX 15?
I have a 1989 Jeep Comanche 4.0 2wd pioneer. i broke the peugeot ba 10 in half and i was wondering if i need to do anything special to install the ax 15. its 2wd so i was thinking if i get the yoke with the trans it should bolt directly up. will the master cylinder work and should i get the clutch for the ax 15?
I changed mine over from the Peugeot to the AX15 and was able to keep the original clutch components, however, because I switched to 4wd I cannot comment on driveshaft length or splines. It isn't too difficult of a swap but get as many components as possible from the donor vehicle. Good luck, Tom
