Need direction... driver side firewall
Yup, 1/4" or 6.5mm bolt.  It is captured so it won't come the whole way out but you need to unscrew it to separate the inner and outer halves of that connector.  A deep well socket is best, or a regular sized socket with a tiny extension.....there's not alot of room to work in there.
To follow this.  Look at this lip.  On the bottom it  has 2 on each side they look like it stays to the outside of the connector but the top part looks like it was clipped on the inside as the plastic of the housing is pushed out .   Whats yall opinion on this. It fits better inside but i feel ot should be ouside.
