Quanah Parker Posted March 10, 2019 Share Posted March 10, 2019 Here is a pic of my alt bracket. As you can see it is broke. I see by online pics there are two different types of mounts. My question is are the Aluminum one piece style like I have interchangeable with with the steel ones I see in online pics. Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 10, 2019 Share Posted March 10, 2019 That is an AC delete alt mount. That aluminum piece is where an AC compressor would otherwise mount. That will be a hard piece to find, I've only seen one and maybe I should have grabbed it. You also have that idler pulley to contend with, IDK if that is a separate piece or attached. And FWIW that does not look like the correct upper rad hose. Link to comment Share on other sites More sharing options...
Quanah Parker Posted March 10, 2019 Author Share Posted March 10, 2019 2 hours ago, Jeep Driver said: That is an AC delete alt mount. That aluminum piece is where an AC compressor would otherwise mount. That will be a hard piece to find, I've only seen one and maybe I should have grabbed it. You also have that idler pulley to contend with, IDK if that is a separate piece or attached. And FWIW that does not look like the correct upper rad hose. This truck never had A/C so does that mean the other mount will work? Yes the idler is part of the mount so if I eliminate it is there a shorter belt that would work without the idler? Anyone have an alternator area pic of their 2.5 without air? Yes I know hose is incorrect. This is a project truck so I plan on replacing all the hoses. Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 10, 2019 Share Posted March 10, 2019 Call these guys- Mr. Complete Jeep 2635Jackson AveMemphis, TN. 38108901-452-9090 Link to comment Share on other sites More sharing options...
