Bulto Posted December 16, 2018 Posted December 16, 2018 So the 10A dimmer fuse on my 90' comanche pops as soon as I turn the key. Everything still works except for the gauge lights. Took the gauge cluster out all the lights look fine, tried to find any obvious short but was not successful. Any recommendations would be great.
Ωhm Posted December 16, 2018 Posted December 16, 2018 I'm using the 88 Elect Manual, so this could be apples to oranges comparison. Disconnect the Head Lamp Switch, with good fuse in, turn Key On. Does fuse still blow?
Bulto Posted December 16, 2018 Author Posted December 16, 2018 Ok I disconnected the dimmer switch turned the key and it didn't blow. Plugged it back in turned the key and it didn't blow. This is all with the gauge cluster out. So the problem has to be in the gauge cluster then right?
Ωhm Posted December 16, 2018 Posted December 16, 2018 25 minutes ago, Bulto said: So the problem has to be in the gauge cluster then right? Yeah if cluster is disconnect, problem seems to be cluster.
