Cherokeefever Posted November 17, 2018 Posted November 17, 2018 89 jeep Comanche, long bed, 5speed Bobbed 17" Custom build numbers 1 3/4 DOM exo cage CSI 12,000 winch Iron rock 3 link long arm kit Rustys 8 inch front coils with 2" spacers Stock rear leafs with 1" blocks Home made relocation brackets Iron man rear shackles 4.0 with 4 hole injectors and bored out throttle body, K&N Air filter Front Dana 44 that is sleeved, Has C- gussets, Detroit locker, Chromoly shafts AX-15 tranny with a Rubicon 4:1Transfer case. Rear Dana 44 with Chromoly shafts, Disc brakes and a spool. 17" DV8 aluminum beadlocks with 37" Maxxis Trepadors. 1 1/2 DOM Tie Rods and Track Bar Solid Diff Covers, 4:88 gears
Pete M Posted November 17, 2018 Posted November 17, 2018 need some daytime shots   did you plate the whole frame or just the locations where the tube meets it?
