NorthWest Fab has a yoke that I think will likely work.
http://www.northwestfab.com/1310-NP205-Cast-CV-Yoke_p_2409.html
You will need to measure your seal housing/seal to confirm, but I believe you'll need a different seal too, as the 1350 flange that's currently on there should take a seal with a larger ID.  I think the one they list as going with it (for NP205 application) will likely work, but you would have to measure.
Another option would be to get a Dodge 1350 CV driveshaft and change the yoke at the axle end or run a conversion joint.
