comanche-man22 Posted August 24, 2007 Share Posted August 24, 2007 i need to know where the speedometer cable is located at and how to pull it cuz i need to replace mine...pics would be nice but the info is more important! Link to comment Share on other sites More sharing options...
rockhardzj Posted August 24, 2007 Share Posted August 24, 2007 Transfercase tailshaft housing. You will see a cable go in right there. it leads up, alongside fuel/brake lines, and into the firewall, to the back of the gauge cluster. Link to comment Share on other sites More sharing options...
comanche-man22 Posted August 24, 2007 Author Share Posted August 24, 2007 alright so how do i take it out? Link to comment Share on other sites More sharing options...
rockhardzj Posted August 24, 2007 Share Posted August 24, 2007 I/m not sure, I know the tcase end comes out by one bolt, and then a good tug job. The speedo end, I pryed the plastic part away, but i think I broke the plstic part doing it... :roll: I went electronic anyways, so I could care less... :D Just be careful on the speedo end. Link to comment Share on other sites More sharing options...
comanche-man22 Posted August 24, 2007 Author Share Posted August 24, 2007 I'm at the speedo end and i am having a hell of a time i have got down to where you can see the blue plastic piece where everything screws into and i can see where there is a plastic clip like thing behind the rpm gauge that has to be popped out and i don't know how to take off the rpm gauge without hurting it...i need some serious advice!! 8) Link to comment Share on other sites More sharing options...
JohnQ Posted August 24, 2007 Share Posted August 24, 2007 Mine was like a child proof cap, I had to squeeze both sides and it popped right off. Link to comment Share on other sites More sharing options...
comanche-man22 Posted August 24, 2007 Author Share Posted August 24, 2007 yeah i know but my question is how do i remove the rpm gauge to get to it? Link to comment Share on other sites More sharing options...
JohnQ Posted August 24, 2007 Share Posted August 24, 2007 yeah i know but my question is how do i remove the rpm gauge to get to it? I pulled the whole cluster out as much as I could and reached behind to unhook it. Maybe this thread will help: http://comancheclub.com/forums/viewtopic.php?t=3963&highlight= Link to comment Share on other sites More sharing options...
Eagle Posted August 25, 2007 Share Posted August 25, 2007 yeah i know but my question is how do i remove the rpm gauge to get to it? You don't. There is NO need to remove the tachometer to get at the speedometer cable. The speedo cable is a push-on connection to the speedometer head. You squeeze the two sides of the white nylon retainer and the cable comes right off the speedo. Link to comment Share on other sites More sharing options...
comanche-man22 Posted August 27, 2007 Author Share Posted August 27, 2007 i got it done but the little electronic clip on the back behind the tachometer that is where i had trouble! but thank you guys Link to comment Share on other sites More sharing options...
