Master7122 Posted August 16, 2018 Share Posted August 16, 2018 I recently swapped from the Peugeot trans to the AX15 in my 88 comanche. I also converted it to external slave (trans came from a 94 XJ so it was already external) everything went smoothly, trans didn’t leak a drop of fluid the entire way home in the back of my bed. Now that it’s installed it’s leaking like crazy from the bellhousing (as if the input shaft was leaking?!?) i used the correct pilot bearing, AX15 clutch kit ect... i know it’s trans fluid because it’s thicker and smells like gear lube but to be safe i replaced the rear main, oil pan and valve cover gasket... still leaks Link to comment Share on other sites More sharing options...
87MJTIM Posted August 16, 2018 Share Posted August 16, 2018 Could be the front bearing cover not sealed properly. When you were driving home with it, was it full of fluid? Now that it is full, the leak is obvious. That would mean dropping the trans and resealing the cover. Link to comment Share on other sites More sharing options...
Master7122 Posted August 16, 2018 Author Share Posted August 16, 2018 24 minutes ago, 87MJTIM said: When you were driving home with it, was it full of fluid? Yes it was full coming home Link to comment Share on other sites More sharing options...
