MuchRespect Posted July 29, 2018 Posted July 29, 2018 Had a new clutch slave cylinder installed in my AX15 and went ahead and replaced the clutch while they were at it. Now, it's got a very slight knock when I first fire it up and at low RPM it's got a intermittent knock coming from what sounds like could only be the transmission (behind and beneath cab, not from engine compartment). Drives great, just put 500 miles on a road trip, but sounds pretty rough. Any ideas on what could be causing it?
a bum with money Posted July 29, 2018 Posted July 29, 2018 Did you take it back to the shop that did the work? That would be the first thing I would do. Let them look it over. Doesn't sound good.
DirtyComanche Posted July 29, 2018 Posted July 29, 2018 They could have done a lot of things wrong. Might be a bolt backing off the flywheel or pressure plate, might have broke a finger jamming it together, might have put the wrong pilot bearing in and the input shaft is flopping around, might have forgot to tighten up a bellhousing bolt, might have put something together wrong in the tcase shift linkage, exhaust, or transmission mount, or whatever else. Take a look for yourself first, but you paid to have work done so I would take it back to them.
