I would suggest checking the links at the starter relay. On my truck there is also a 40 amp fuse on the ignition switch to starter relay wire. don't know if that is default or if PO put it there. But if that blows I get a no crank. Might be a bad igition switch.
/mathias
Skickat från min iPhone med Tapatalk
Glad you got her going. :applause:
My starter is going too, same problem. I just cycle the key a whole bunch of times until the starter catches. It's working for now, but I need to fix it before it leaves me in a pickle.
Glad u found the problem.
Tracing gremlins around the starter relay is pita.
/mathias
