USAFAGumby Posted June 7, 2018 Posted June 7, 2018 Anyone know where to find some new bed shims or what they are called? Ive looked for bed pads and spacers too and got nothing. If i can't find any new ones i might have to make some i guess. Thanks! Sent from my SM-G930V using Tapatalk
HOrnbrod Posted June 7, 2018 Posted June 7, 2018 The Mopar bed shims are NLA. The bed uses a 10mm bolt as I recall, so you'll need shims with a slot a little bit wider than that. They are called automotive body panel shims. Here's one place you can get them: https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dautomotive&field-keywords=Body+Shim+U-Type+&rh=n%3A15684181%2Ck%3ABody+Shim+U-Type+
krustyballer16 Posted June 7, 2018 Posted June 7, 2018 Washers would work too...I used some on one riser.Sent from my SM-G892A using Tapatalk
