88whitemanche Posted May 28, 2018 Share Posted May 28, 2018 What’s up fellas what techniques you guys use to swap the o-ring out? Is it just that simple? Pull whole assembly out replace o-ring and reinstall? Link to comment Share on other sites More sharing options...
DesertRat1991 Posted May 28, 2018 Share Posted May 28, 2018 Is there a dipstick o-ring on the 2.5? My 4.0 didn't have one. The tube was just press fit into the hole. That said, when it started leaking I pulled the tube and sealed that junction with a bead of hi-temp RTV silicone. Problem solved. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 28, 2018 Share Posted May 28, 2018 10 minutes ago, DesertRat1991 said: Is there a dipstick o-ring on the 2.5? My 4.0 didn't have one. The tube was just press fit into the hole. I had to look it up. There's no o-ring shown for either engine on the dipstick tube, but some of the later model dipsticks had an o-ring just below the handle. I use a later model dipstick and there's an o-ring on it. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted May 29, 2018 Share Posted May 29, 2018 My 88 has a 94 AW4 in it. When I pulled the dipstick off, there was an o-ring that was falling apart, dry and funky...so when I put it back together I picked up a new o-ring, put some anti-seize on it, no sweat. Find O-rings by the single at ACE or by the random pack at any parts store with a HELP! section. Link to comment Share on other sites More sharing options...
88whitemanche Posted May 29, 2018 Author Share Posted May 29, 2018 only spot that has oil on the engine currently and for sure I’m losing oil and i am quarts shorts when doing oil changes Link to comment Share on other sites More sharing options...
