bigmistake Posted May 14, 2018 Share Posted May 14, 2018 I've got a '91 that has some issues with the parking brake. The brakes work fine, but the light in the dash won't come on when the brakes are active. When I turn the truck on, the dash light shows up, so I know the bulb isn't out. The handle to release the parking brake is also missing - all that remains is a frayed looking wire. Pulling the wire releases the brake, no problem. Any thoughts on replacing the handle? I'm guessing find a handle in the JY and rig it on there... I haven't been able to find an assembly to replace it with. Thanks for any input! Glad to finally be a Comanche owner! Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 14, 2018 Share Posted May 14, 2018 43 minutes ago, bigmistake said: I've got a '91 that has some issues with the parking brake. The brakes work fine, but the light in the dash won't come on when the brakes are active. When I turn the truck on, the dash light shows up, so I know the bulb isn't out. The handle to release the parking brake is also missing - all that remains is a frayed looking wire. Pulling the wire releases the brake, no problem. Any thoughts on replacing the handle? I'm guessing find a handle in the JY and rig it on there... I haven't been able to find an assembly to replace it with. Thanks for any input! Glad to finally be a Comanche owner! There is a switch on the brake pedal assembly itself Take the kick panel off you'll find a single wire and connector Switch completes a ground circuit Link to comment Share on other sites More sharing options...
bigmistake Posted May 14, 2018 Author Share Posted May 14, 2018 Thanks! Looks like that is what it is. There is a little tab that looks like it is bent out of shape. When I push it down, the light comes on. Will see what I can do to get it connecting again. Link to comment Share on other sites More sharing options...
