CEThomas Posted August 14, 2007 Share Posted August 14, 2007 Drive train = trans + T-case. It makes it easy and quick to bolt the trans & t-case to the 4.0 and then slide in as one unit. Link to comment Share on other sites More sharing options...
FxRacing282 Posted August 14, 2007 Share Posted August 14, 2007 alright cool so i need to do the following: fuel system (what about fuses??any problems) electrical and drivetrain. what about the radiator any suggestions there? does the 2.5 have any differences radiatorwise than the 4.0 H.O.? Link to comment Share on other sites More sharing options...
CEThomas Posted August 14, 2007 Share Posted August 14, 2007 You will need: Radiator Radiator brackets Radiator upper & Lower radiator hose PS pump if you have the PS on the 2.5 4.0 Fuel lines to hook up the the fuel line All the wiring under the hood Computer Trans Dash with all the wiring inside Fuel pump / fuel sending unit and some other items I know I have not thought of. The power dis box and fuse box on the wiring will have your fuses. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted August 15, 2007 Share Posted August 15, 2007 alright cool so i need to do the following: fuel system (what about fuses??any problems) electrical and drivetrain. what about the radiator any suggestions there? does the 2.5 have any differences radiatorwise than the 4.0 H.O.? If it's in the engine compartment, and isn't related to brakes, you need to swap it. same with interior wiring. so you'll need the radiator and support panel from the 4.0 Link to comment Share on other sites More sharing options...
FxRacing282 Posted August 15, 2007 Share Posted August 15, 2007 sounds like some good hard work Link to comment Share on other sites More sharing options...
JeepcoMJ Posted August 15, 2007 Share Posted August 15, 2007 sounds like some good hard work it's easier than I make it sound. if I can build what I've built, you can swap a 4.0 into your 2.5 without much issues. Link to comment Share on other sites More sharing options...
