ORCA Posted August 7, 2007 Share Posted August 7, 2007 Finally got this weird thingamajig in place with one problem in my eyes... Here you can see where I had to grind down the end of the brace and make the hole way bigger: This was so that the hole on the brace and the two holes in the straps. The brace right out of the box did not fit what so ever (here it is modified to fit): MORE could have engineered it better and saved me an extra 1-2 hours of work. Probably would take an extra 5-10 minutes on the manufacturing end... Anyway it is installed and hopefully it will keep my box in place :redX: What do you think? :nuts: Link to comment Share on other sites More sharing options...
Oizarod115 Posted August 7, 2007 Share Posted August 7, 2007 it wasnt MOREs fault man, we've got a rusty's (same identical setup) steering box brace and it didnt fit out of the box either. we chocked it up to the catastrophic hydroplaning incident and other accidents the XJs been through edit: we also bought a RE frame stiffener for the new RE trackbar mount and stuff on the same X and it didnt fit AT ALL either Link to comment Share on other sites More sharing options...
JeepcoMJ Posted August 7, 2007 Share Posted August 7, 2007 I'm gonna say that by how bent up the front of the frame is (as pictured in your pic), that it's not MORE's fault either. maybe your rig was in an accident and it's tweeked just a little bit. also, I'd slide the end of the brace between the two clamps rather than bolted onto the side. it would offer more supporet I think. Link to comment Share on other sites More sharing options...
UNL1MTD Posted August 7, 2007 Share Posted August 7, 2007 also, I'd slide the end of the brace between the two clamps rather than bolted onto the side. it would offer more supporet I think. x2 check this thread http://www.comancheclub.com/forums/view ... e&start=15 page 2, almost at the bottom, some pics of the installed brace Link to comment Share on other sites More sharing options...
ORCA Posted August 7, 2007 Author Share Posted August 7, 2007 I'm gonna say that by how bent up the front of the frame is (as pictured in your pic), that it's not MORE's fault either. maybe your rig was in an accident and it's tweeked just a little bit. also, I'd slide the end of the brace between the two clamps rather than bolted onto the side. it would offer more supporet I think. Woops...you caught me. I did leave out that my manche was in an accident (PO!!! :roll: ) So yes I suppose this would affect the fitment. Now I tried mounting inbetween the straps and it was rubbing on the flywheel horribly. This is the only way it mounts up (on my truck anyway). :cry: Link to comment Share on other sites More sharing options...
comanchedude Posted August 9, 2007 Share Posted August 9, 2007 I have the same brace and it fit no prob, also the bar does go between the clamps that’s how it fit on my MJ It really does a good job of stiffening up the steering system Link to comment Share on other sites More sharing options...
