agamble Posted November 23, 2017 Share Posted November 23, 2017 Before I tear my interior apart for the answer to my question I thought I would come here and see if someone already knew. Currently my comanche has doors with manual windows and locks. I need to replace the passenger door, but I can only find replacement doors with power windows and locks. If end up going that route, can someone tell me if the wiring harness is already there (either male or female connectors) for power windows and locks, making it a plug and play affair. I am I looking at wiring everything up myself? Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 23, 2017 Share Posted November 23, 2017 If the truck doesn't have power window / locks from the factory the cross-body harness won't be there. The wiring isn't difficult......... Link to comment Share on other sites More sharing options...
agamble Posted November 24, 2017 Author Share Posted November 24, 2017 Makes sense, if it wasn't there from the factory the cross-body harness wouldn't be there. Thanks for the information and response. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 24, 2017 Share Posted November 24, 2017 4 minutes ago, agamble said: Makes sense, if it wasn't there from the factory the cross-body harness wouldn't be there. Thanks for the information and response. I have a wiring diagram for the power windows if you need it, using the stock power window panels, switches, and switch pigtails. Link to comment Share on other sites More sharing options...
agamble Posted November 24, 2017 Author Share Posted November 24, 2017 Yes I do need that. I have been unable to find a wiring schematic during my online searches. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 24, 2017 Share Posted November 24, 2017 PM me a address and I'll send it. Link to comment Share on other sites More sharing options...
Minuit Posted November 24, 2017 Share Posted November 24, 2017 Another option that uses all OEM parts is to get the cross-body from a 91 or 92 XJ with power windows. The only wiring required is to swap a few wires around on the driver side if it was a 4dr XJ that the harness came from. That would also give you a very easy jumping off point if you ever wanted to add power mirrors - you'd just need to add the switch and mirrors themselves. You'd need 91+ doors to match. Link to comment Share on other sites More sharing options...
