700r4 into 2.5l
What vac lines u talkn about , if memory serves me right there shouldnt be any vac lines fer the 700r4. just fab ur self a TV cable bracket off the tbi, adjust it properly and if its an electricaly opperated over drive then run a manual switch in to the cab to activate the OD . if there are any vac lines any on the engine then cap or remove as necesary.
700r4 are easy to adapt on to everything because they aint computerized
