Jaime Posted September 19, 2017 Share Posted September 19, 2017 Hello, It seems that I need to replace my turn signal switch on my 88 5 speed. When I push the handle, up or down, it might work sometimes but mostly not. I can make it work sometimes if I wiggle the handle and then hold it when it works. I've searched here without any luck. I got some luck on YouTube. My question is there a trick on getting the wires down the column . The videos I've seen show them cutting the old wires and then taping the new connector to the old wires. But it only goes so far then stops. After that they just ran the wires on the outside of the column. Is this the way to do it or is there some trick? Oh by the way I haven't taken it apart yet. Just want to get some info before I do. Link to comment Share on other sites More sharing options...
87MJTIM Posted September 19, 2017 Share Posted September 19, 2017 (edited) Don't cut it. Just attach a string or wire to the old one. Pull the string up the column. Tie to the new harness and pull back through. You also may have to loosen some part on the steering column Edited September 20, 2017 by 87MJTIM auto correct was incorrect Link to comment Share on other sites More sharing options...
Jaime Posted September 20, 2017 Author Share Posted September 20, 2017 Thanks for the reply. I just didn't know if there was a special trick to feed the wire thru. Link to comment Share on other sites More sharing options...
