Something I notice yesterday only when my lights are on.  The right blinker light stays in. But works correctly when the blinker is actually turned on.
Any ideas or thoughts for a fix?
Check the socket that houses the turn signal bulb , could have corrosion. mines has been like that forever and I still haven't gotten to replacing it.
here's a vid on how to replace it
Usuly a grounding issue. These jeeps seem to ground back to the cluster for some reason.
Our 91 has short in the same socket, turn signal indicator only lights up on when the running lights /headlights are on. Tried new bulbs, problem persisted. Kept cleaning it out and screwing with the contacts about gave up but it's working now.
Found old a junk headlight harness to steal a socket from next time it happens.
Sent from my iPhone using Tapatalk Pro
