Green Mesa XJ Posted September 12, 2017 Share Posted September 12, 2017 Located on the cylinder head? Then it might be possible, probably need the corresponding plug then work out if you can wire it in. The old jeep system is dead simple all of the gauges go to the gauges and not a ecu. Unless you've got some early ecu . I. Now the 2.5 in 1886 were renix, California emission should be the only worry with the 2.8.Alternatively find and swap back the 2.8 sensor. All of them should match up to the wiring harness. If that's not possible then gm has all kinds of plugs and pigtails available you would need to hunt down a catalogue on line of check a few stores. Probably very common. Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
AMC86Kid Posted September 12, 2017 Author Share Posted September 12, 2017 does anybody know what the original connector to the temp sensor on the 2.8 is ? if i can find that connector then maybe i can connect those two wires to my new sensor and get my temp dash gauge to work and Green Mesa XJ you say that on the 86 all the sensors get wired directly to the gauges in the dash ? if that is true then what I'm trying to do is definitely possible Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted September 12, 2017 Share Posted September 12, 2017 It's that red wire with flat look spade connector. I see it in your photo, next to the bluish green wire. Not sure what that plugs in the picture in to, probably the two prong temperature thingy. This is how mine looks Mine harness is 1986 federal emission (no computer). The beauty of the 3.4 swap beside you can swap it all and it's plug and play is if you ran the Camaro injection with ecu spliced in the old XJ harness would connect to the senders like oil, temperature and alternator like before and work. Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
AMC86Kid Posted September 12, 2017 Author Share Posted September 12, 2017 ok so after tinkering around i had connected these two wires like you said i tried to both sensors but could only get a response with the way its currently hooked up and i was able to get the temp gauge to move from 100 to this do you guys think i figured it out ?? how can i be sure i have it hooked up correctly i sure wish i could find some info on the two prong sensor so i could read up on it and see exectly what its made for Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted September 12, 2017 Share Posted September 12, 2017 red wire goes to the temp sender . In my crowded picture it's just one wire going to that sender. I'm surprised it sending anything Edit it looks like the picture attached to the cylinder head. Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted September 12, 2017 Share Posted September 12, 2017 86 temp sender on cylinder head, With wiring going to itVery hard to see it just follow the red wireSent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted September 12, 2017 Share Posted September 12, 2017 Looks like you've got a slug threaded in the place where the sender should go. If you have the 2.8 still it's the right hand front of it Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted September 12, 2017 Share Posted September 12, 2017 This is where you sender should be but it's not, since it's a rebuild head with something threaded in to keep it from leaking . Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
AMC86Kid Posted September 12, 2017 Author Share Posted September 12, 2017 no i don't have the 2.8 engine just a few parts from it but i do agree with you that the red wire goes to the gauge maybe i just have to pull the coolant sensor out and screw in the correct sensor in its place then connect the red wire but I'm not sure what the correct 2.8 sensor that would be Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted September 12, 2017 Share Posted September 12, 2017 I'll try to look it up, it was a common gm sensor but it's not in the catalogues now. I just bought one a few years ago for my 30 rebuild which hadn't moved past rebuilding the engine in the garage stage. Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
AMC86Kid Posted September 13, 2017 Author Share Posted September 13, 2017 is this the 2.8 temp sensor http://www.rockauto.com/en/moreinfo.php?pk=930679&cc=1181393&jsn=731&jsn=731 do i just connect the red wire to it and it should work what do you think ? Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted September 13, 2017 Share Posted September 13, 2017 No it will not even screw into the cylinder head, that's for a 2.5 or 4.0 jeep motor Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
AMC86Kid Posted September 13, 2017 Author Share Posted September 13, 2017 thats what rock auto has under 2.8 what sensor do you think it should be Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted September 13, 2017 Share Posted September 13, 2017 Ok I did wright down which one worked for the 2.8 , but I can't find my note book I've been marking down what parts i use. Looking at my order history.... It looks like 213-80 gm Lost of firebird guys say this fit their v8s so it on the right track Or it could be the G1852 Some say it's for 70s v8 and vortex cylinder heads. I'm almost certain it's 213-80 gm, it looks just like the part in the engine in my garage. But I can't guarantee it just be fairly sure. Shop around on price and maybe a local shop will have something on the shelf. Took me years to find that sender, all of the catalogues I hit were wrong, even got the 4.0 sensor you posted earlier on my shelf Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
AMC86Kid Posted September 13, 2017 Author Share Posted September 13, 2017 Can you post a link of that sensor is it the same one in your pic Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted September 13, 2017 Share Posted September 13, 2017 Same one in my picture of the engine i am rebuilding. eBay search or Amazon . The one in the 2.8 in the jeep I never had clear access to it. 213-80 Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted September 13, 2017 Share Posted September 13, 2017 Btw somebody else may know a better part # this is the best I've found after years of searching. Or maybe a you pullit Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted September 13, 2017 Share Posted September 13, 2017 Maybe ts76 standard or 1T1008 airtex/wells with the spade terminal. Hard to tell from the picture Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
AMC86Kid Posted September 13, 2017 Author Share Posted September 13, 2017 hmmm well that sucks I'm hoping somebody would actually know that way it would save me the pain but i guess i will buy it at orileys and return it if i can't get it to work so theoretically i can get the sensor replace it where one of the other sensors are connect the red wire and then see if my temp gauge responds correctly guess that will be my plan is this it right here https://www.amazon.com/ACDelco-213-80-Original-Equipment-Temperature/dp/B000C9L7DI how do you connect the red wire to it? Link to comment Share on other sites More sharing options...
Eagle Posted September 13, 2017 Share Posted September 13, 2017 On 9/11/2017 at 11:08 PM, AMC86Kid said: i got the carb working by putting in a bypass pressure valve so the fuel constantly cycles and the carb sounds like it just sucks in gas as it needs it i don't think its the radiator the guy who sold it to me said that he took it to a shop and got it pressure tested also when i squeeze the bottom hose wich i think is the inlet hose i see the air bubbles pushing threw the rad and coming up to the cap the radiator or the fluid inside of it is not hot just the engine is, thats why i think something is blocking the flow because if it was flowing then the fluid would warm up as well i would guess that the temp of the engine gets around 150-175 You do realize that the normal operating temperature is around 210 degrees (F), right? And the temperature at which water boils at sea level is 212 degrees. All internal combustion engines are too hot to touch at normal operating temperature. You can't go by touch, that's why we have temperature gauges. Link to comment Share on other sites More sharing options...
AMC86Kid Posted September 13, 2017 Author Share Posted September 13, 2017 yes i have learned that it gets over 180 degrees because i had to buy a new thermostat thats rated at 180 but how hot is the radiator allowed to get because mine gets pretty hot and i added a big fan maybe the coolant to water ratio is not 50 /50 and thats why it gets warm very fast Link to comment Share on other sites More sharing options...
Marine1Texas Posted September 13, 2017 Share Posted September 13, 2017 Water gets hotter faster then ethylene / propylene glycol . However ethylene / propylene glycol will retain heat longer then water. Never have more then a 50/50 mix unless your in places like Alaska. Here in Texas I run a 20/80 Mix since we never get below 0. I also use water wetter or hyper lube super coolant in all my cars. I use 1 bottle in my 4.0 jeep. The water wetter or hyper lube super coolant makes the coolant/water more conductive, by ridding the bubbles between the metal and liquid. On our dirt track truck we play around with, we use 3 bottles of hyper lube super coolant with straight water, it is 4.0 and runs at 190 even when it is 110 outside. Never go by tough lol use a gauge of some kind. They have thermal readers that you can check the temp of the metal to see the difference in temps. Link to comment Share on other sites More sharing options...
AMC86Kid Posted September 13, 2017 Author Share Posted September 13, 2017 when you say 20/80 mix do you mean 20 coolant to 80 water mix also i called orileys and they don't sell the ACDelco 21380 temp switch but they crossed referenced it to this https://www.oreillyauto.com/detail/bwd-3123/lighting---electrical-16777/switches-16486/a-c-switches-16500/coolant-temperature-sensor-sender-switch-11362/temp-sender-gauge/wt359/2617460/1994/pontiac/firebird?q=Wt359 my only concern is the part where it says this: Temperature Range (Deg F): Closed At 100 Degree, Open At 220 Degree does that mean it will only keep track of my engine temp up to 220 and then it won't go any higher? Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted September 13, 2017 Share Posted September 13, 2017 Sounds like an idiot light temperature range. Dunno. I've had trouble sourcing the correct sender so my guess of 213-80 is only a guess as I haven't installed the new motor yet. If oreilly has a temp sender with gauge in their book for the 86 I guess give it a trySent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
AMC86Kid Posted September 14, 2017 Author Share Posted September 14, 2017 ok so here is where I'm at i got a new temp sensor this one: http://www.autozone.com/engine-management/temperature-switch/duralast-temperature-switch/129205_173479_10199_5673?&searchText=tu66 the guy at autozone told me that its an OEM equivalent to the AcDelco 21380 i screwed it in and connected the red wire and ran my motor with no luck the gauge in the dash stayed at 100 degrees i do believe that this is the correct sensor to use however i do not know how the gauge in the dash works it could be something simple like my gauge is not grounded or my vehicle is not grounded properly but who knows also i found this remember the hole in the corner that you were talking about it looks like the 2.8 sensor would screw into it since the hole appears smaller http://www.rockauto.com/en/moreinfo.php?pk=930679&cc=1181393&jsn=384 but of course i would have to connect it to my gauge in the dash and i don't think it would work anyways so at this point id say i should get a new gauge and try to hook it up to one of my temp sensors any suggestions on what gauge i should get and how to hook it up so i can get a good measurement at what temp my engine is running at Link to comment Share on other sites More sharing options...
