CRM1988 Posted September 11, 2017 Posted September 11, 2017 I am looking at putting a 2" lift on my stock 88 pucks in the front and add a leaf in the rear my question is can I put 31x10.50x15 on my stock rims and run them without having to do any cutting on my truck?
Dzimm Posted September 11, 2017 Posted September 11, 2017 Yeah you should be OK. Lift to tire size questions are one of those "your mileage may vary" kind of things so there is a small chance you may get some very minor rubbing at full lock on a camber but overall you should be fine. Just make sure you bump stop properly to avoid any contact that may occur.
CRM1988 Posted September 11, 2017 Author Posted September 11, 2017 44 minutes ago, Dzimm said: Yeah you should be OK. Lift to tire size questions are one of those "your mileage may vary" kind of things so there is a small chance you may get some very minor rubbing at full lock on a camber but overall you should be fine. Just make sure you bump stop properly to avoid any contact that may occur. Thanks for the input
