1990 front axle
Hi guys, have recently picked up my 3rd mj, 2 wd, 1991 long box, with 5 speed(AX-15) newer 4.0, serial # search says it has 3:07 rear diff. Would like to convert to 4wd.Local jy has a front 4x4 axle from 1990 Cherokee serial # search says it has 3:07, I am gonna assume it would be vac operated, which I again assume is an easy fix? Question is should I look into using transfer case from the 90 Cherokee or look for a later year, would the 90 Cherokee have a Peugeot tranny or Ax15?
Sent from my iPad using Tapatalk
90XJ could have either trans. You would need to confirm
Sent from my SM-N910T using Tapatalk
No. The BA 10/5 was phased out early in the 1989 model year. Most '89s had the AX-15, and all '90s had the AX-15.
The rear diff is Dana 44, finding 3:54 for the 44 might be a challenge but probably not impossible, something to dwell on, was just happy to find the 3:07 and hadn't thought about changing ratio.
So the transfer case from the 90 should be compatible with the AX15 in my 91?hoping to pull everything from the one cherokee..
Been corrected, but I believe early AX15 are 21-spline. Would need to confirm.
Finding 3.54 gears for a Dana 44 is a walk in the park. EVERYONE has gears for the Dana 44.
