Key switch spinning free no clicking...not staring just stuck with ignition on thought it was key cylinder put in a brand new cylinder still same problem please help
Look down on the column under the dash. There's a rod that goes into the actual ignition switch from the tumbler that the keys goes into.
Thank Cruiser..upon further inspection i noticed this part was broken i'm guessing this is part of the actuator rod.. or is it something else and how do i remove it and replace it and can i get that part new or do i have to pull it from the junk yard...also this plastic piece fell out from around the turn signal switch area while i was removing that pastic around the column can some tell me where it goes ?
