1995 Cherokee No Start
Title says it. The jeep was running just fine and the next day I went to start it, it would crank but not fire. I have checked the cps and it reads good. Ended up replacing it with a new one from Napa because I still did not have spark. This did not fix the problem. I then pulled the ignition coil. It looked like it could have been on its way out so I replaced it with a new one from Napa. This did not fix the problem. Discovered I do not have power to the coil. All fuses and relays are good and have not found a bad wire. Thinking of making a jumper wire if possible to see if we can get it running. At this point my brother and I are stumped. Any one have an idea of what can be done next?
Checked the Ecu last night. Everything looked to be good. Got a code 12 because I had left the battery unplugged. Got a draw from the aftermarket stereo installed by the previous owner, I think. Also got a 54. Related to the distributor sensor?
Code 54, bad sync sensor - there's your problem. It's the round disk directly under the distributor cap on your 95. P/n 56027023. Pick up a genuine Mopar if possible. Also check it's harness for broken wires and/or connector for bent pins.
