Misc. XJ, MJ, TJ parts NH
BIGHEEP
97+ XJ header panel with wiring and drivers front fender. Very small dent or cracks. Red, clear coat is chipping $100
97+ XJ front light harness $10
Rare XJ wagoner grill and headlight bezels. Chrome is in good shape $100
MJ shifter console small chip, broken tabs $10
Somewhat rare MJ Eliminator center console insert (same as XJ but e brake slot is blocked off) cracked pretty good. Epoxy it? Sale pending
Hens teeth rare MJ colum shift 4WD lever console , mint sale pending
Rare XJ floor mount E break handle. $25
XJ mint radiator support. $10
MJ stock replacement rear shocks, only mounted then removed. 0 miles $20
MJ bench seat brackets, $20
TJ stock replacement front shocks. Maybe 300 miles on them. Missing one rubber donut. $25
TJ front sway bar with almost new end links. $20
TJ 2" spacer lift $40
Local pickup on larger items.
Archived
