mjeff87 Posted July 28, 2007 Share Posted July 28, 2007 So it was really hot this morning when I was at the junkyard, scavenging parts. I wanted to get a Dakota rear brakeline (longer) since I'm up 3+ inches in the back now, and the stock MJ line is acting as a limiting strap at the moment :oops: How in Hades does that junction block come off the Dakota axle??? The D44 has a bolt thru it which secures it, but the Dakotas don't have anything....how are they held to the axletube? I was too hot and tired to mess with it. Didn't want to try prying on it and screw something up, if there was a hidden fasterner, or it had a threaded stud underneath I didn't know about. Jeff Link to comment Share on other sites More sharing options...
rockhardzj Posted July 29, 2007 Share Posted July 29, 2007 Mother effin dammit! I knew I forgot to get something at the JY today... Link to comment Share on other sites More sharing options...
Rokhound Posted July 29, 2007 Share Posted July 29, 2007 Mother effin dammit! I knew I forgot to get something at the JY today... :D :cheers: :D Link to comment Share on other sites More sharing options...
mjeff87 Posted July 29, 2007 Author Share Posted July 29, 2007 glad I stirred your memory......but how do you get it off the axle???? I'm gonna run back down today. There's about 10 Dakotas in there, so I ought to figure it out, eventually. Link to comment Share on other sites More sharing options...
rockhardzj Posted July 29, 2007 Share Posted July 29, 2007 glad I stirred your memory......but how do you get it off the axle???? I'm gonna run back down today. There's about 10 Dakotas in there, so I ought to figure it out, eventually. If theres 10, try hammering one off, see if maybe its just stuck on... Link to comment Share on other sites More sharing options...
mjeff87 Posted July 29, 2007 Author Share Posted July 29, 2007 The breather is threaded, fits thru the junction block, and into the tube. I just had to clean all the gunk off to figure it out. One little problem, the Dana axles have a seperate breather, and the blocks are held on by a 5/16" bolt. The Dodge axle breather is 1/2" fine thread....I'll have to drill and tap out the axletube to make it work. Jeff Link to comment Share on other sites More sharing options...
87manche Posted July 30, 2007 Share Posted July 30, 2007 just weld a stud on the tube and secure with a nut and washer from the top. that's how the 8.8 got it's weirdo dakota hose secured. Link to comment Share on other sites More sharing options...
mjeff87 Posted July 30, 2007 Author Share Posted July 30, 2007 Got a pic or two of that Nate? :D Might be just as easy for me to drill/tap right now, seeing as how it's stripped... Image Not Found Link to comment Share on other sites More sharing options...
87manche Posted July 30, 2007 Share Posted July 30, 2007 no, I don't have pictures of most anything. just go and get a bolt of suitable size, weld it head down to the tube, then just slide the junction over it and secure with a washer and nut on the top. then I just reused my stock D35 vent tube with the 8.8's vent. Link to comment Share on other sites More sharing options...
