89 Comanche TCU upgrade
I swapped a 94 AW4 into my 88 and thought (musta read it somewhere) that I needed the 94 TCU that came with it.  Wrong.  The TCU has to plug in to a same COLOR connector.  The break was 1990 to 1991. The 88 TPS input from the 94 TCU showed 0.0  I never got any input reading from the TPS with my voltmeter. So after poring over wiring diagrams I noticed that the 94 TCU used different pins that the 88-90.  Fast forward >> I scavenged a Renix cab forward harness AND a Renix TCU from the yard with the same color connector.  Did the trick.
To answer the original question and echo Cruiser...the wiring inside the 91+ TCU is d-I-f-f-e-r-e-n-t.  The pin out is different, the pins all fit, but it's whats inside that counts. There is no advantage to putting in a newer era TCU into a Renix.  If the power/comfort switch is a problem...jump the wires and put it in power mode all the time.
Sorry if I'm rambling, I'm usually in bed by 10.
