IronManche87 Posted May 25, 2017 Posted May 25, 2017 Howdy all! So I recently had my cylinder head resurfaced and a valve job and I noticed my temp sensor was all messed up.. Will it be okay to drive until I can get one?? When I swapped the engine in my xj I just used a wire with alligator clips to connect the plug to it temporarily and it worked just fine but I'm wondering if I just don't connect it at all, will it mess with too much and affect driveability? Thanks in advance y'all! Sent from my LGMS210 using Tapatalk
DirtyComanche Posted May 25, 2017 Posted May 25, 2017 The one in the head is only for the gauge. You don't "need" it. Just don't overheat it...
IronManche87 Posted May 26, 2017 Author Posted May 26, 2017 The one in the head is only for the gauge. You don't "need" it. Just don't overheat it... Lol awesome thank you sir! Sent from my LGMS210 using Tapatalk
