comanchedude Posted February 27, 2006 Share Posted February 27, 2006 Question I just completed an SOA and I don’t like how little slip yoke is left in the tail shaft It is only about 1.5 inches and that is quite a bit less than stock and I am sure that will pull out off road So I want to install a longer drive shaft yoke I understand the YJ yoke will work and is an inch longer Does anyone have one for sale or can you direct me to a good site to buy a new one that is not 60+ dollars? Thanks Link to comment Share on other sites More sharing options...
XJ Maki Posted February 27, 2006 Share Posted February 27, 2006 The YJ slip yoke is really only about 5/8" longer. My driveshaft was still a little short with the YJ slip yoke (6" lift). As fate would have it I twisted my driveshaft the first time out so I ended up getting it re-tubed to the correct length anyways. They aren't too hard to find since they're often traded out for CV driveshafts. Should be about $30, try ebay, and both jeepforum.com and jeepsunlimited.com have very active classifieds. Link to comment Share on other sites More sharing options...
Bounty Hunter Posted February 27, 2006 Share Posted February 27, 2006 Are TJ slipyokes similar to the YJ slipyokes? I've got several of those and would send you one for $30 +shipping. bountyhunter@sija.org . I need to do this to mine after the SOA, maybe tomorrow and I'll let you know. I'll take pics. Link to comment Share on other sites More sharing options...
mr4x4 Posted February 27, 2006 Share Posted February 27, 2006 rubicone express has one part#1822 its about $70 to $80 its 5/8 longer Link to comment Share on other sites More sharing options...
mjeff87 Posted February 27, 2006 Share Posted February 27, 2006 The advantage of the YJ yoke over the XJ/MJ isn't so much the added length, but rather the wider spacing between the yoke ears to help prevent binding at increased angles: (YJ on L, XJ on R) It is a bit longer though, about 1/2".... Jeff Link to comment Share on other sites More sharing options...
comanchedude Posted February 27, 2006 Author Share Posted February 27, 2006 Thanks for the info I priced to have my shaft extended and balanced, $90.00 that’s what I will do to have the length back to original ., Link to comment Share on other sites More sharing options...
