shdbriding Posted July 25, 2007 Share Posted July 25, 2007 I have been lurking around here for a couple of months getting good info from old posts and such, now its time to start asking questions. I picked up an '86 Comanche X with the 2.8(soon to be 3.4) and I seem to have most of the bugs worked out of it except for the steering. It is very touchy compared to anything else I have driven before. I bought this from the back lot of a used auto place they were selling it as a parts truck. The previous owner had installed a 3" lift. From what I can tell the only parts that were installed were shocks, springs(aal in the back) and sway bar drop brackets. Now for the questions. #1 For a 3" lift do any other parts need to be changed other than the ones mentioned above. If so please list and possibly some sources for these parts. #2 What length trakbar is needed for a 3" lift so I can figure out if that was changed yet? #3 Where can I get extended sway bar links so I can get rid of the drop brackets and fit my factory skid plate where its supposed to be and not in the back yard? (don't need disconnects as i won't be doing any rock crawling or such just the occasional trip up in the woods for fire wood) You can tell the lift and the tires have been on for a while with no unusual wear pattern on the tread so I don't think the alignment is all that bad. Thanks in advance for any info. :chillin: Link to comment Share on other sites More sharing options...
carnuck Posted July 25, 2007 Share Posted July 25, 2007 Check the brake hose length (my '86 was fine but the '85 XJ wasn't) Used stock tracbar (can be relocated) No idea on the swaybar stuff. I have 5 1/2" front coil with a tracbar and lower arms, plus shock extenders and brake hoses. Nothing else in front. Link to comment Share on other sites More sharing options...
