jon1998 Posted April 11, 2017 Posted April 11, 2017 Hey everyone, I am trying to install a transmission oil seal on my 2wd Comanche with the AW4. I am not sure which way to put in. There are two sides, one of which has a garter spring and a lip around the edge; does this side face towards the inside of the transmission or out? Thanks
Jeep Driver Posted April 11, 2017 Posted April 11, 2017 Spring has always gone inboard on every seal I've installed.
HOrnbrod Posted April 11, 2017 Posted April 11, 2017 Hey everyone, I am trying to install a transmission oil seal on my 2wd Comanche with the AW4. I am not sure which way to put in. There are two sides, one of which has a garter spring and a lip around the edge; does this side face towards the inside of the transmission or out? Thanks Is this the seal in the tailshaft extension that the slip yoke rides in?
jon1998 Posted April 11, 2017 Author Posted April 11, 2017 Hey everyone, I am trying to install a transmission oil seal on my 2wd Comanche with the AW4. I am not sure which way to put in. There are two sides, one of which has a garter spring and a lip around the edge; does this side face towards the inside of the transmission or out? Thanks Is this the seal in the tailshaft extension that the slip yoke rides in? Yes sir
HOrnbrod Posted April 11, 2017 Posted April 11, 2017 Then you might want to check the bushing right in front of the seal. The bushing gets egged out over time resulting in a sloppy slip yoke and leaking rear seal. Special tools are required to change out the bushing, and a transmission shop doesn't charge much to replace it - about an hours labor.
jon1998 Posted April 11, 2017 Author Posted April 11, 2017 Then you might want to check the bushing right in front of the seal. The bushing gets egged out over time resulting in a sloppy slip yoke and leaking rear seal. Special tools are required to change out the bushing, and a transmission doesn't charge much to replace it - about an hours labor. Ok, I'll take a look at that, thanks for the replies
