omega_rugal Posted April 1, 2017 Share Posted April 1, 2017 i was reading the modes of operation of the Renix ecu and that during the "crank mode" if wide open throttle is detected the inyectors would shutdown, to clear any flooding.... btu what about the ignition? does the spark is shutdown too? Link to comment Share on other sites More sharing options...
Ωhm Posted April 1, 2017 Share Posted April 1, 2017 No. Your trying to start the vehicle and you don't need any more fuel. Link to comment Share on other sites More sharing options...
omega_rugal Posted April 1, 2017 Author Share Posted April 1, 2017 ok i get that also there`s a crank signal coming from the relay to tell the ECU the engine is being started, if this wire is not connected, it means the ECU will stay in "key ON mode" and thus not start? damn it a HEI won`t be that picky... Link to comment Share on other sites More sharing options...
Ωhm Posted April 1, 2017 Share Posted April 1, 2017 Should just tell the ECU to shut off the fuel pump relay during crank. Starter relay will supply battery voltage to the fuel pump. By-passing the ballast resistor. Disregard this foolish statement I made. ECU does not shut off the fuel pump relay. Link to comment Share on other sites More sharing options...
omega_rugal Posted April 1, 2017 Author Share Posted April 1, 2017 whatever, disconnected the TPS... starts right over now... excuse me i`m going to hang myself... Link to comment Share on other sites More sharing options...
