Well I decided to start tearing into the interior to get my floor owns squared away. I attempted to take my passenger lower seat belt off to remove the interior trim pieces. Well the rust was so bad, that the entire attachment came out. Has anyone dealt with this before? Would love some ideas and possibly some pics if there are any out there.
I cut a section from a donor cherokee that had the seatbelt nut attached and welded it over where the original should be.  But that bolt may back out if you heat it till it glows.
Great idea! I was thinking about welding a seat belt nut to the 2x6 piece of metal in the pic. The 2x6 is my rocker and seems to me like a good place to attach the seat belt too.
  • 6 months later...
  • 1 month later...
On 9/26/2017 at 9:31 PM, Big Dan said:
Is the above what you ended up doing?
No I just ended up drilling a hole in the metal and putting a nut on the other side.
