Juan Perez Posted July 23, 2007 Share Posted July 23, 2007 hey whats up guys. in the next couple of weeks I'm going to swap my cooling system from closed to an open system. has anyone here ever done this upgrade? if so any tips on this upgrade will be appreciated. i have a 87 comanche 4.0, 2wd automatic.will have pics soon. Link to comment Share on other sites More sharing options...
Rokhound Posted July 23, 2007 Share Posted July 23, 2007 It has been done. I have never done it but from what I have read on here make sure you buy a NEW 3 row radiator I had a link for it somewhere i will look and see if i can find it found it: http://jeep.off-road.com/jeep/article/a ... ?id=257864 Link to comment Share on other sites More sharing options...
offroader461 Posted July 23, 2007 Share Posted July 23, 2007 i did it and it was very simple and easy..i swapped the following and did it this way: -new 94 XJ radiator w/cap -new hoses top and bottom (not necessary) -new 94 XJ heater valve -all new heater hoses -i used my original pressure bottle as an overflow tank...just drilled the cap big enough for the hose and it works great...any questions just ask me...did mine 2yrs ago and my truck doesnt run above 210 ever :D planning on doing the same thing with my 90XJ Link to comment Share on other sites More sharing options...
ROADLESS Posted July 23, 2007 Share Posted July 23, 2007 There are essentially two ways to do it. A complete conversion (the one that I highly recommend), and a 'budget' conversion which retains most of your original equipment. For the complete version i used Craig's writeup located here: http://www.olypen.com/craigh/rad.htm Craig even includes part #'s :D ! Here is the budget version by Joe Thompson (MADXJ): http://www.madxj.com/ It is under his engine writeup section. I have done both of these on various XJ's and my MJ. IMO the complete conversion is the only way to go. However, if your on a budget and need something 'temporary' then Joe pretty much covers what ya need. Good luck :wrench: ! Link to comment Share on other sites More sharing options...
