89 4 liter 5 speed.
Has 20 to 22 psi running with the regulator hose on and off.  Pressure drops immediately to 0 when shut off.  I pinched off the rear fuel line while running and it dies.  Checked with 2 different gauges.
Is the rear rubber line the return or supply?  I assumed it was the return since it was rubber and the front line into the regulator is steel.
I read pressure should be 30 and 39 with vaccuum line off, so something is wrong.
What pump should I get?  I don't see them for sale.
Oh it barely runs, has no power won't rev much above idle. I did manage to drive it home.    I just bought it and am going through its issues. I hooked up my fuel injection flush and before I could get it started the can ran dry.  I guess it went back up the supply or return line, not sure.  Never had that happen before. There is a recent receipt in the glovebox for a fuel pump.
