1992 2wd to 4wd help
That's not an ideal setup for your 92. Look for a 92 -95 transmission and transfer case they'll bolt up and plug in with no chsnges to what you have. But see if the guy selling the MJ parts has the driveshafts and shift linkage and shifter for the transfer case. Also all brackets for tcase linkage. 92-99 XJ will also give you a better front axle.
96-99 will give you larger ujoints in the axle also.
That transmission will bolt up.  Make sure you retain the flex plate from your current trans.  The wiring might not be the same though, and the TV cable and internals are not.  You can make the TV cable fit, but it's tight, I think I could pull up a picture of how I did it on my XJ if you want.
It would be more ideal to find a later XJ that is being parted out and steal the trans/tcase/front driveshaft/shifter/linkage.
