grinch Posted February 8, 2017 Share Posted February 8, 2017 Long story short the previous owner put a light bar on my MJ and I'm considering removing it. I don't really use it and it makes a lot of annoying vibrating sounds at highway speeds. Anyway, I'm looking at the mounting brackets and I see these screws: I'm assuming these are some sort of security screws or something but I don't know. I'm trying to look up in the little holes to determine a thread pattern but can't tell. Any ideas on how to get these buggers out? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted February 8, 2017 Share Posted February 8, 2017 Those are rivets , you need to drill the heads off . Link to comment Share on other sites More sharing options...
desbennett004 Posted February 8, 2017 Share Posted February 8, 2017 ^^^ yup, just drill through them with a small drill bit, they will come right out. I've heard putting a bit of black silicone in the top of the fins on the back of the light bar helps to stop the noise and vibrations. Don't have first hand experience of that though, but might be worth a try? Sent from my SM-N900W8 using Tapatalk Link to comment Share on other sites More sharing options...
grinch Posted February 9, 2017 Author Share Posted February 9, 2017 I figured it would be something simple like that, herp derp, thanks guys! And yeah I've tried putting gorilla tape around the fins and it definitely helped with the lower speed noise, but it still makes noises at higher speeds. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted February 10, 2017 Share Posted February 10, 2017 The position it's mounted on the a pillar makes a difference as well. Mine is mounted just below the roof level, where as my brothers it mounted slightly higher. His whistles, mine doesn't. But mine does have slightly more wind noise above 45. Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
