Dzimm Posted January 27, 2017 Author Share Posted January 27, 2017 I was saying crankshaft but the relay clicking is the auto shut down. If and when it does it again do as I said. Even though you put a new Crankshaft sensor in it can be bad or a loose connection. OK. I did try the spit method initially to no avail and I didn't hear any relays clicking while doing anything with the crank sensor but I will keep it in mind if it happens again. Thanks! Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 27, 2017 Share Posted January 27, 2017 Normally an open or short in the ASD relay circuitry will throw a code (P1388). But like all codes, if the problem is intermittent maybe ood it won't. If I were you I'd invest in a decent code reader and check your vehicle periodically for OBD2 Pxxxx codes. Link to comment Share on other sites More sharing options...
