lazyt Posted January 21, 2017 Share Posted January 21, 2017 I have an 86 MJ completely stock. I plan to install a 3"-3.5" lift shortly. I am new to the "modern" jeep world and would like to know what wheel size(15x8 etc.) and tire size would cause the least amount of clearance issues/headaches. I thought maybe 15x8 with 4.5" backspacing and 11/32.50's. Any suggestions? Link to comment Share on other sites More sharing options...
Eagle Posted January 22, 2017 Share Posted January 22, 2017 You seem to be approaching this in reverse. The usual sequence is to (1) find that certain trails require more ground clearance than your rig provides; (2) select a larger tire size (and wheel size if the tires are too large for OEM wheels; and then (3) select the amount of lift necessary to run the selected tire size. Before I would consider trying to answer your question, I would want to know why you think it's necessary to lift your truck, and how you arrived at the choice of a 3" to 3-1/2" lift. Link to comment Share on other sites More sharing options...
Pete M Posted January 22, 2017 Share Posted January 22, 2017 general rule of thumb is that 31s will fit well with that combo. 32s are likely to rub the fenders, especially with less backspacing. Link to comment Share on other sites More sharing options...
Eagle Posted January 22, 2017 Share Posted January 22, 2017 Actually, 31s will fit (on OEM Jeep rims) with no lift at all, and work very well with a 2-inch budget boost. Once you go higher than 2 inches you start to need other things, such as control arms and adjustable track bars. I bought my '88 Chief with a 4-inch lift and drop brackets, and I wheeled it like that on 31s for a couple or three years. Then I had an attack of sanity, removed the lift, and I was much happier. Link to comment Share on other sites More sharing options...
Dadinator Posted January 23, 2017 Share Posted January 23, 2017 Yep. Cheapo 2" Lift with 31's on the old mule. The 31's fit stock, but look much better with the 2". Link to comment Share on other sites More sharing options...
